cranks no start
  • cranks no start
    I have 2 festivas 92 and a 93 that will not start after siting up for a month or so.I have power to the coil but no pulse from the stator.Has anyone had this problem or is it just a coincidence?
    When you unplug the Distributor there was some corrosion on 1 of the pins in the distributor.I cant find my evtm at the moment so not sure what that wire goes to any help would be appreciated.
    P.S.I have checked all the basics,fuel,timing belt etc.
    96 Ford F-150 XLT
    93 Festiva L (Modified)
    92 Festiva L
    68 Mustang GT 428cj
    anyone got a wiring diagram?
    96 Ford F-150 XLT
    92 Festiva L
    68 Mustang GT 428cj
      What do you mean by the stator? (do you mead the rotor?)
      How does the engine run after strated? How does it run when only sitting a couple of days.
      Check the connection of the hi tension wire (the one from the center post of the dist. to the coil) at the coil end...notorious for contamination and corrosion.
      Alos check the post intside the distributor cap....alot of aftermarket ones oxidize terriblly.
      Lotsof electrical schems....more specific please.
      Joe Lutz
      The SKATE ..... 1992L 5spd
        stator is the pick-up device inside the dizzy. Stator stays still, Rotor rotates. That's how I remember it.
        Jim DeAngelis
          What's a dizzy?
          Joe Lutz
            dizzy= distributer
            Jim DeAngelis
              Try swapping distributors?
              White '89L auto - Sold!
              Silver '06 Rav4, 95k!
                TTTTTTIIIIIMMMMMMMMMEEEEEEAAAAAAAHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHHhhhhhhhhhhhhhhhhhhhhhhhhhhhh!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!i!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                Jim DeAngelis
                  wiring diaghram of the ignition system,I dont have a dist to swap out.Both cars have never run after they quit both doing the same thing to.I suspect some corrosion in the dist.
                  I will prolly pull the dist. out tmorrow at work if we are slow.
                  96 Ford F-150 XLT
                  92 Festiva L
                  68 Mustang GT 428cj
                    hahahahha.....
                    Someone had a little too much turkey on Thanksgiving!
                      too much turkey, not enough beer...
                      Jim DeAngelis
                        Ignition Schematic (1992 Ford Section/page 21-1) is available (7.8 Mb - jpg format). Need E-mail address('s) and/or link where to post it. All help is appreciated.
                        Joe Lutz
                          diagrams
                          phantom_smack@yahoo.com
                          96 Ford F-150 XLT
                          92 Festiva L
                          68 Mustang GT 428cj
                            thanks
                            96 Ford F-150 XLT
                            92 Festiva L
                            68 Mustang GT 428cj
