Hi everybody.
I've changed the front right bearing on my Mazda 121 a week ago and most of the time it seems to be working fine.
BUT
I must have pulled the shaft out while I had the hub dismantled (had to struggle to get it open and disconnected). I am sure I pushed it in back quite hard and the splines had engaged and I felt a thunk as if the shft had clipped in place. The problem is that in normal driving the shaft simply seems to slide out from its place leaving the diff to spin freely - once it's happened only a minute away from home and another time in a choke-point of a busy intersection (not the nicest place to try and fix it). Anyway, both times me and my bro managed to push it back in place (with the car jacked up) and move on.
So, my questions are:
Do any of you know what kind of clip hold the front shafts inside the diff? Any idea how to remove/replace it and if any special tools are needed? Is this a part which you can find easily at any spares shop and what do I ask for?
On a completely different topic, what are these shims I keep hearing about when you replace front wheel bearings? I did not find anything that even looked like a shim, and I changed nothing except the bearings themselves and the oil seals. There was something like a very thick washer, some 4mm between the inner and outer bearings, is it that and are there any problems if I reused the old one???
Thanks for everything
NxP
BUT
NxP
