Has anyone actually seen this tool?
It appears that in essence it is just a bolt with two washers on both sides tightened with a nut. If we tighten this bolt to 200nm as recommended, i.e. almost the maximum torque an average man can apply to a bolt, the inner bearing will be overtightened and it will be not possible to rotate the whole assembly with a torque of 0.25-1.8 nm to select a proper shim.
Can anyone explain - what's the trick with this tool?
