So yeah I've got my drive axles replaced. Greased up the tie rod ball joints (I believe this is what they're called? Please inform me.) The pieces inside the dust collectors on the tie rod ends. So those are nice and loose. Retightened those. Had the lower control arm disconnected during install and what not so those couldn't have been damaged. Same with the tie rods. Disconnected during work.
Now the problem... When I'm going over 55, if I hit the brakes... It seems to pull to the left as if something was dragging... Kind of like something maybe is clogging the brake line on the left side? Or maybe an uneven wear? Possible rotors are goin to crap? I'm not sure. Ideas?
Also... another result of the repair... When I turn the wheel past half way, it pulls its self into the turn and i have to pull twice as hard to recover it to straight.
Ideas on these?
Ideas on these?
