i have 2 88's, Scrappy (the "black" one) has what i'd call a normal clutch pedal position. Boo, on the other hand, has a pedal that rides about 3" higher (closer to driver), and not level with the brake pedal. is there any way to adjust this so that the brake and clutch are more closely matched? it's not a real big issue, just annoying when switching between cars.
odd clutch pedal position...
Tags: None
hmmm, the haynes manual tells how, I think, although I have never done it. When I get done with the job I have to do to mine, if I can, I will find and scan you one in, or someone may beat me to it......Contact me for information about Festiva Madness!
that's exactly what i'm looking for. according to the pictures, all i have to do is remove the cable from the fork arm and adjust the pedal switch untill desired hight is achieved? sounds preaty easy.Trees aren't kind to me...
