hello i need some help with my '93 festiva..it died one day at a stop light..i put a new fuel pump in..i then saw on here that it could have been(and most likely was) the distributor..so i put one in out of a running festiva..buuuuuuuuuut she still doesn't start..it'll crank over but the tach stays at 0000rpms any help would be apprieciated
need some help
WLE,
It would help if you put your location in your profile.
Someone maybe close by and can give you a hand.
Go to the heading above and click on profile and add your location there.
You may want to check the fusible links under the hood behind the battery and coolant reservoir.'93 Blue 5spd 230K(down for clutch and overall maintanence)
