Coolant lines going into throttle body.
  • Coolant lines going into throttle body.
    Can I bypass the coolant lines going into the throttle body? Has anyone done this before?
    Why would you want to do that.
    Joe Lutz
    The SKATE ..... 1992L 5spd
      absolutley, people have done it many times to gain a tiny amount of horse power, I doubt you would see a gain on the b3 or even the bp but you can do it however.
        What is the sensor that those coolant lines go to?
          I didn't know that they went to a sensor. I can look at my haynes and see if I can find out for you.
            These lines do not run to a sensor (on the B3/B6 at least). You can bypass the TB which will keep your intake air a little cooler, but if you live in cold climates you run the risk of getting a stuck throttle body (thats the purpose of the coolant running through there). I debated doing the same mod but decided the teeny gain on my B6 would not be worth the risk.
            ~Nate
            Current cars:
            FOTY 2008 winner!
