I have a 91 Festiva GL. Right after I bought I smelled gasoline while driving it home. I checked all the connection through both of the access plates in back. They don't appear to be leaking. The foam padding that seals the gas connection area on top was dry but wet with gas on the bottom front. I pulled the tank. (Still had maybe a quarter tank of gas) Most of it had leaked out from an almost full tank. Problem is I could not pinpoint where the gas is leaking from. Any ideas.
thanks ahead of time
kned33
kned33
