Could use some input towards a few minor repairs on my 1989 Festiva.
1. Radiator fan is stuck "on" 100% of the time. I removed the the "sending unit(?)", cleaned connections, installed, same result. I did purchase a new "sending unit", but I wanted to check with you guy before I installed it and wasted my money because it might be something else.
2. Temp Gage doesn't work. (Did you know gage and gauge are correct word spellings for same instrument?..... I didn't 'til I Googled them
3. Fuel Gage doesn't work....assume it's the sending unit in the tank?
4. Bright light switch works in the you-hold-it mode, but not in the just bright light mode.
Any help would be appreciated. Thanks.
