1989 Mazda 323
  • 1989 Mazda 323
    I am interested in buying a Mazda 323 that the guy says is stuck in 4th gear. I'm only guessing, but let's say it's a throw out bearing. Obviously I would change clutch plate, pressure plate and throwout bearing. How hard is this to do and what kinda cost are we talking about using McAuto parts?
    #2 .....Cheesehead
    #3 '91 White - Donor Car
    #4 .....Montana Project
    SOLD----Levistiva for $1500
    Bought her back for $450
    If it is stuck in a gear, then I would guess that the problem would be other than the clutch. A gear box can be shifted regardless of clutch condition. I would look at externals to the transmission such as linkages first, but I would not be surprised if it turned out to be a internal transmission issue. Good luck and keep us posted.
    1991 L 408,000 miles+ w/NEW B3 longblock!!
    2008 Nissan Versa S HB
      Tough call, could be a few things. Best case scenario is its just a linkage or so, worst case being a fricked up internal.
      If the car is cheap, it will be worth the risk because finding a 323 transmission is not that hard.
      I'm with b3, the clutch shouldn't make any kind of difference to whether the car will shift out of a gear or not. Try reefing on it really really hard first. lol.
      -1991 Mazda RX-7 Turbo - Large Street port, Megasquirt, GT4088R, Meth injection.
      -1993 Festiva L
        For any tranny,,,,if if you cann't get it from gear to nuetral it's not a clutch or through out bearing problem........................................... .................................................. .............................(period)
        BUT! it might not be an internal tranny problem....it could be a linkage problem between the shifter and the tranny.
        Joe Lutz
        The SKATE ..... 1992L 5spd
          I am guessing the shifter gate has broken inside .
          HD2500 Duramax Chevy
          Z28 LS1 power 500 +
