OK, I'm a new Festiva owner and looking forward to driving this car if I can just get it running, looking for some help while I'm waiting on repair manual to get here to see if I can find the problem. Here's the info
I'm Jeff, the car is in West Central Missouri
1993 Festiva GL, automatic
Car has only been driven a few hundred miles each year the past 3 years, last February it wouldn't start, previous owner had fuel pump replaced and ran fine. Parked the car for a couple of months and then it wouldn't start again, and that's when I bought it from them.
Turns over and has spark but no fuel, will start for a minute if you spray starter fluid in the intake. The inertia switch is not tripped and I noticed today that the fuel gauge is not working either, also put in about 4 gallons of gas just to make sure it wasn't empty, gauge still didn't move when turning the key on,not sure if that's related or a seperate problem?
I've read on here about a wire near the firewall that you can use to check the fuel pump system but not sure which one, mine has 3 single wire plugs there and then a couple multi-wire ones too.
I've read lots of great info that you folks have posted on this site so I'm confident you will get me pointed in the right direction.
Jeff
Jeff
