Hello again,
Lately my 88 LX has developed a serious issue with the carburetor. When I drive the car around for a bit, the engine bogs down for a bit and then at that point, the only way to keep it running is to rapidly press the accelerator. When starting the vehicle, it will run for a second and then die. The issue is related to the carburetor for sure as the car runs slightly better with the carburetor from another 88 LX. The car will run for as long as I pump the accelerator but as soon as I release the pedal or if I just hold it down, it will just stall and die out.
