Anyone know where to buy this part? It's the one piece sensor inside the distributor for the 90-93 Festie's. If I can find it, it should be cheaper than the entire distributor. I've been on google for about an hour with no luck.
Crank position sensor J 927
1990 L-Plus, 5-spd, Flamed Festiva.
http://i163.photobucket.com/albums/t...STIVA_0011.jpgTags: None
HI jg, I just checked both your links and the only thing I found (on both) was a pick up coil or stator, but neither looked like the crank position sensor in mine. Typing c p s in the search reveavled nothing. How did you find the listing? Thanks,
Clev1990 L-Plus, 5-spd, Flamed Festiva.
I tried cutting the links for rockauto and napaonline...both sites dump on higher level pages...I searched using 1992 festiva; rockaut (~40$)...napa (~60$)...both have picts of the inductive coil (stator).Joe Lutz
The SKATE ..... 1992L 5spd
