does anyone have a wiring diagram for a 95 aspire?
  • does anyone have a wiring diagram for a 95 aspire?
    i bought the car and a lot of the wires were disconnected. i got some of them figured out but a few are not hooked up. as soon as i figure out how to post pictures i will.
    Ebay item 142907103379
      http://www.bbbind.com/tsb-wiring-diagrams-database/ will probably have them.
          got it i sent away for the electrical and vacuum troubleshooting manual for 9.00. it just arrived yesterday. got everything working except the washer pump (bad pump), the horn, the interior light (bad bulb), dim headlight on the drivers side, a couple of connectors i haven't figured out yet, the blower motor, the previous owner just bypassed everything and ran a wire to the battery and through a switch and stripped the wire back and wrapped the wire around it and tapped it off.
            Check the ground on teh horn. Tends to rust down there behind the bumper. Folks tend to move them up into the engine compartment.
              as soon as it stops raining i will look at it again. by the way what size is the exhaust pipe? about half of mine is missing probably the catalytic converter. sounds noisy without it and the backend drags on the ground.
