I blieve after doing the timing belt on my 93 festiva a couple months back I must have knocked loose the seal on the coolant bypass tube that goes under the exhaust manifold. Where the two connect it is leaking pretty good there. Any advice on fixing this? I don't know where I could get replacement parts, none of the pull and save places around here have festivas or any junkyards either. The tubes are so rusty I don't know if a new rubber seal that goes in there would help either. Any ideas? Thanks
Any help with coolant bypass tube leaking..
I bent mine on accident and the O-ring wouldn't seal anymore so I cleaned it really well and packed it full of JB Weld Putty and then did a layer on top. I don't drive the car every day but it has been like that for 3 years with no leaks."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
I have had occasional leaking of those tubes over the years on my fleet of Festies.
If a source for this part (new only) is known, I would buy a dozen of them to add to my "lifetime supply" of Festy parts.88L black, dailydriver
88LX silver a/c, dailydriver
4 88/89 disassembled
91L green
91GL aqua pwrsteer
92GL red a/c reardmg
1952 Cessna170B floatplane
