Hello, and thanks in advance for your time, and help.
Replaced the battery terminals today, because things were looking corroded. Tidied up and placed the key in the ignition. On first turn, the dash lights and door signal beep were on, upon turning the key to the ignition, nothing happened, no noise from the starter or anything else. Checked +/- connections, fuses, fusible links, battery, etc. etc. Nothing happens when I turn the key in the ignition now. Took the time to upgrade to the Bussman FLF fusible links and took my time cleaning, protecting and inspecting all connections that I had made. No dice. Has anyone experienced this before?
