After I spent an entire week swapping out the tranny in my 1989 Festiva, it ran great for three days. As I was driving home from dropping off my wife at a friend's house, it just simply quit running. Without any tools, the only diagnostics I could do were 1.) check for trouble codes - there were none. 2.) check for spark - nice sparking... not the problem. 3.) listen for the fuel pump... hmm. not a sound.
So I hitched a ride home, got my flatbed trailer and put my Festiva up on it and took her home. I traced the fuel pump through all the way to the airflow sensor. The fuel pump turns on when I move the vane just a tiny bit. I'm not sure if this is normal, because I seem to recall hearing the fuel pump turn on for a period of time just by turning on the ignition switch. The fuel pump also turns on while engaging the starter motor... this I know is correct according to the fuel pump relay wiring diagram.
The problem could still be the airflow sensor, that thing just above the air filter with the big hose running over to the intake manifold. But the other thing I noticed was a humming/buzzing sound coming from what I think is the IAC valve. I only think that because when I unplug it (two pin connector) the humming stops, and I get a trouble code 34.
So the questions are: Is this the IAC valve, located behind the distributor near the rightmost fuel injector? Is the IAC valve supposed to be making noise? I don't recall hearing it before.
Please help... I'm stumped.
Zuddie
Zuddie
