I'm aware of the one in the thermostat housing for the temp gauge; the one that activates the fan relay; the O2; and the coolant sensor. What others are on this engine and where are they located?
How many sensors does the '90 Festie have?
1990 L-Plus, 5-spd, Flamed Festiva.
http://i163.photobucket.com/albums/t...STIVA_0011.jpgTags: None
cooling fan temp sensor, engine coolant temp sensor, EGO (O2) sensor, these three you already know. They provide the PCM with information. I'll list wether the sensor provides info to the PCM or gauge.
Throttle Posistion Sensor, on throttle body, PCM
Vane Air Flow Sensor, on top of air filter, PCM
Power Steering Pressure switch (if equipped), on PS line, PCM
Crankshaft Position Sensor, inside distributor, PCM
Clutch Engage Switch (mtx), on clutch pedal, PCM
Neutral Gear Switch (mtx), on transaxle, PCM
Neutral Safety Switch, (atx), PCM
Ignition Module, inside distributor, PCM
stop lamp switch, rear def switch, headlamp switch, blower motor switch, both AC relays, and atx kickdown switch also provide a load input to the PCM.
Fuel tank sending unit, in tank, gauge
oil pressure switch, back of block, gauge/lamp
brake fluid level sensor, master cyl res, gauge/lamp
brake warning lamp switch, brake combination valve, gauge/lamp
park brake switch, park break lever, gauge/lampJim DeAngelis
kittens give Morbo gas!!
Originally posted by FB71cooling fan temp sensor, engine coolant temp sensor, EGO (O2) sensor, these three you already know. They provide the PCM with information. I'll list wether the sensor provides info to the PCM or gauge.
wow! all hail FB71! :cheers:89SX funtop! Fully loaded!
RIP 90LX
Isn't there also a barometric pressure sensor inside the PCM?
The air inlet temp sensor (thermistor) and the vane, both in the VAF, come in as one combined signal and the barometric pressure sensor valvue is added (actually multiplied) to provide the CPU with a true mass air flow.
The combined temp and baro values equal the air density...the vane position represents inlet air speed. The result represents the amount of oxygen going into the combustion chamber....thus the CPU knows how much fuel to add.
Also, the barometric pressure sensor is also necessary for automatic altitude comppensation.Joe Lutz
The SKATE ..... 1992L 5spd
jg, yes, I forgot about the baro sensor in the pcm. The Festies don't have a separate or integrated IAT. The PCM uses the ECT to guess at inlet air temp. IAT sensors showed up Aspires.Jim DeAngelis
Thanks, I appreciate the list.1990 L-Plus, 5-spd, Flamed Festiva.
From memory...last time i had the VAF off...when i looked in the outlet...I saw the thermistor penatrating below the circuit board.
Also just guesing....i think the cooling fan relay input to the PCM to prevent the idle from droping out.Joe Lutz
correct on both counts, Joe.
cooling fan input is for "electrical load", to stabilize idle speed.
The thermistor you see in the VAF is not a separate IAT, and it's not considered to be an IAT at all. The MECS guys used to call it a 'temperature compensator". It modifies the VAF signal directly. Aspire got a separate IAT with direct input to the PCMJim DeAngelis
^^no one would believe how many smart people we have here on the site... I really appreciate them sharing the knowledge."FLTG4LIFE" @FINALLEVEL , "PBH"
So do I!!! If you don't do it yourself, you can't be sure it's done correctly.Originally posted by GenevaDirt^^no one would believe how many smart people we have here on the site... I really appreciate them sharing the knowledge.
I don't trust ANYONE to work on my vehicles and any advice that I can receive is well appreciated.
I was out of town when the engine went out my festiva (hole in the piston, year 2000) and I instructed my wife to contact a local garage/engine repair/replace shop. I was in touch by phone but the engine has never been right since that time. That's the same problem that I'm working with now. Final words from a 60 year old retired Army Green Beret (VietNam), retired Texas advanced math teacher, and general all around 'old school' tinker'er; if you can do it yourself, DON'T TRUST ANYONE!!! Follow advice on this board and do it yourself.1990 L-Plus, 5-spd, Flamed Festiva.
There is an engine electronics diagram in the back of the Haynes manual which shows the wiring for the sensors connected to the car computer, also the wiring for the "actuators" which do stuff. "Sensors" and "actuators" are generic names which were used in a real time computer course I took in the early 90's. There is one sensor on the carburetted engine which is only required in California. I suppose they add it at the Cailfornia dealerships as part of the dealer prep.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
California(and Green state )cars are set up from the factory with all the extra sensors and special PCM calibrations.They also have a different warranty period for certain emission components96 Ford F-150 XLT
93 Festiva L (Modified)
92 Festiva L
68 Mustang GT 428cj
