I have a '93 Ford Festiva L. I need to replace both tail-light assemblies; also the front turn-signal cover. My friend found a '93 Festiva GL in a junkyard. Does anyone know if the 'GL tail-light assembly will work in the model 'L, or the turn-signal cover? Thanks for your help.
'93 Ford Festiva L tail-light assembly
All of them are the same from 88-93. You can even get them from overseas for a different look if you wanted."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
TheFestivaStore.com carries the front clear blinker covers as well."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
