i was told if i remove the axle from my 95 aspire the spider gears will fall into the tranny, that would make it really difficult to change the clutch.
what happens if i remove the axles from my tranny?
I believe that gears will stay in place as long as you don't move or jar the transmission but I haven't tested this theory yet. Most of us just keep an extra inner CV Cup to through into the trans for storage."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
I 've had the spider gears fall on me.Ive had really good luck about them not falling.but it sucks when they do.So a quick run down on how I now pull the transmissions .I pop the passengers side axle and leave it in the car but I leave the drivers side axle in the transmission. It will come out with the axle attached .I don't even Jack up the passenger side.Last edited by ricko1966; 10-02-2019, 11:37 AM.30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.
