So proply a dumb question i had to plug my back passager tire took it off everything good plug tire yay sealed. But center cap won't go back on and both back tires if u push on them a little bit feel some plat not like wheel barings just like a littile loose feeling but the tire is allied and tighten good any help would be appreciated thanks
Center wheel caps
The rear wheel bearing should be checked for side to side wiggle every once in a while and torqued back down. Make sure not to over tighten them though because that could cause a whole new issue."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
Is the wheel sitting correctly on the drim? I'd take them off, turn over, and make sure there's nothing sticking to the surfaces of the wheels or drums.
I've had related problems with replacement rims not going on and had to take a file to the hole.
Another problem I've had is the shiny metal cover not staying on which was fixed by deepening the catches with a punch.
Good luck.Last edited by WmWatt; 10-01-2019, 05:21 PM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
