my blower fan was not working and the previous owner just bypassed everything and ran a wire to the battery and through a switch then to the fan it worked but it was dangerous i traced the problem to a bad relay and a bad switch. got the relay at pull and save they didn't have a switch and nobody sells just the switch new. so i took the switch apart and cleaned it and hot glued it back together, it works in all three speeds. now to fix the horn. while i have everything apart i am cleaning all the cr..pout of the center console and trying to clean the carpets.
fixed my blower fan switch
Hooray! well done.
Here's a little solution if you need to get a coolant switch and radiator working w/o replacing the computer or worrying over the original circuit. ( The shop mechanic screwed up my fan circuit when he replaced the water pump a year ago on my Aspire). Use this adapter for a switch and run a new relay to the battery.
https://fordfestiva.com/forums/forum...ing-to-die-for
I'm set to start putting this together- I still have the coolant fan jury rigged, but it also works with the A/C on still, and being Florida I have that on much of the year. Haven't over-heated since the new water pump.
If you have the interior out of the car completely you can pull the carpets and spray them down with some Purple Power and then pressure wash them and they go almost back to new."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
