Hey so before I start, yes I searched for the answer already and I couldn’t find it. Maybe I wasn’t using the right key words but I failed to find an answer.
I’ve got a 2000 Festiva and I need the “gear shift bushes” replaced. It’s the ones on the u-joint that comes off close to the trans. I have removed the bolt that connects the linkage but where the bushings are that need replacing, it appears to be pressed in. How do I go about removing this part? I’m assuming I have to grind it off and just replace it with a suitably sized bolt?
or is this not something that can be done and the whole linkage needs replacing?
also I should add, welding is currently not an option.
Im trying to upload photos, they’re too large of a file so I will sort that out and post them soon
Cheers
Cheers
