Heater blower
  • Heater blower
    My 1991 festiva blower dont come on turn by swtich does anyone have a wireing diagram i think its not geting power to it or relay locations ?
    Most times the brushes inside the motor are worn. Crawl under the drivers side dash. The motor is behind the storage tray/pocket. Tap on it with the switch turned on. If it starts working. Time for a new motor. Until I can replace the motor I keep a long screwdriver handy to tap on the motor with.
      Kool thanks ill try that in the morning
        I got mine going again with a set of window motor brushes from a 91 f150. Also when testing make sure the switch is on high the resistor that controls the speed can burn out then the fan will only work on high.
          I tried the screw driver bump im not sure if its. Geting power does anyone know a wireing diagram or anything for i can wire something to see brushes or new motor ?
            Haynes manual pg 12-38 1988-89 heating and aircoditioning wiring diagram
            pg 12-39 1990-93
            pg 12-40 1194 and later
            You could try a search of this site or of the Internet.
            Wiring dagrams have been posted here over the years.
              Thank u i appreciate
