Brake Rotor Replacement You Tube
  • Brake Rotor Replacement You Tube
    This is a good video which show you how the brake rotors on the Festiva are disassemble and reassembled. Some short cuts were show as they did not always have the proper tools.
    It is a great instruction video with great camera work and comments.
    I watched the start of it,by 5 minutes in I knew it was 10 times more work than how I do them.I did a write up once step by step with necessary tools but have no idea how to find it to link it here. Anyway I've had 7 of these little cars which means, I've done 14 pairs of these wheel bearings with a slide hammer and a piece of all thread rod with knuckles still on the car.
