Hi all,
Im JIm from SA. I have a 93 festiva (WA festive here in downunder shittsville) that had a bad vacuum modulator. It was pulling trans fluid into the inlet and smoking like a bastard. Got that fixed then the mechanical fuel pump was pumping fuel into the oil. Got that done. While the vacuum mod was faulty I always checked the trans fluid (by the book) every morning to keep it topped up. Now that all the above have been "fixed" the car wont shift from 1st to second when cold (without revving its nuts off) and the shift from 2nd to third is odd as the car revs up just before the change.
I'll plug for a new filter (the car is 28 years old and I have no idea how old the current filter is) but the engine has just over 100,000kms. Any ideas on what could be the issue?
1. trans stuffed?
2. band need adjusting?
3. Filter degraded and not drawing enough fluid for smoother changed until warm?
4. something I have not thought of.
would love some experienced thoughts on what the problem could be.
Cheers all
Jim
1. trans stuffed?
Cheers all
Jim
