OBD1 Port location
  • OBD1 Port location
    I'm trying to find the location of the ob1 port, and no luck yet anyone know where to find it?
    Haynes manual doesn't mention one for the feed back carburettor engine. There is a (white plastic) one pin check teminal near the driver's side fire wall for reading stored check engine trouble codes with a mulitmeter but it's easier just to count flashes of the check engine light when turning on the ignition with the pin grounded. "Simply ground the STI and GND terminals with a jumper wire and watch the light on the dash as it flashes stored trouble code(s)." Done that.
      PM me an email address and I will send you a Festiva shop manual and an electrical wiring manual in PDF format.
