1989 automatic 3 spd modulator valve.
  • 1989 automatic 3 spd modulator valve.
    When I got this car it wasn't shifting properly. I located the modulator valve but it was totally disconnected. It doesn't look like the typical modulators that I am familiar with. It is about the size of an oil filter and seems to be mechanical. I have no idea it is bad or just disconnected. I also have no idea how it is suppose to be hooked up. Any information or help would be greatly appreciated. Thanks.
    Modulator valve not mentioned in Haynes manual. A search of the Internet brings up photos and sellers. A search of "problems" brings up general modulator symptoms, nothing specific to the Festiva.
      WmWatt, thank you for your response. There is definitely a modulator onthis car. The vacuum hoses are disconnected and it's non functional. I am hoping someone will know how to restore it so that it can be determined defective or not. Thank you again.
        I think as an experiment you could hook manifold vacuum to the modulator and drive it around. See if it shifts correctly. Couldn't hurt.
          Here's some info - https://parts.olathetoyota.com/blog/...to%20downshift.
            Thank you. I will try that to see if there is any difference. I appreciate you offering your help to me.
