The temp sending unit on the housing for the upper radiator hose, just below on the block. What is the correct part number for that sensor that feeds info to the temp gauge? It's for a 1988 LX
Engine Temperature Sending Unit
E92Z10884C - Ford Coolant temperature sensor ...
Genuine Ford Part # E92Z10884C (E92Z-10884-C) - Coolant temperature sensor. Temperature sending unit. Capri. Festiva. Fits Capri, Festiva.
Different manufactures have different part numbers for this part.
This is the one with the round connector that connects to the instrument cluster temperature display. (Screws into the head near the thermostat housing)
The one that screws into the thermostat housing and has a flat blade connection is the fan switch
The one on the back of the engine that has a two connector square plastic connector goes to the ECMLast edited by 1990new; 09-04-2022, 10:53 AM.
Rockauto does:Originally posted by usmcsgt1968 View PostFord doesn't have it
ULTRA-POWER 1T1002
$2.31
PriceAdd to Cart
Ford no longer carries parts for the Festiva. You have to search the Internet of call and visit local auto parts suppliers. When buying off the Internet be sure you have the right year and model and compare as many websites as you can to make sure the part numbers are the same because some websites list and ship wrong parts. Sometimes you can also check the manufacturer's website to help insure you are ordreing the right part. And check here.
Sorry I don't know part number. 1990new posted Ford part number above. What I usually do is look up part by name on Internet and look at part numbers on websites. Same part from different retailers and manufacturers usually has same basic part number with extra characters. And you can always post here on For Sale/ Wanted forum to see if anyone has one they will part with.
^^^ that difference in the '88 is probably carburetor or fuel injected. '88 was the first year for the fuel injected (in USA anyway) which they had to put on to get the automatic transmission to meet fuel efficiency standard in USA. The poster has the LX model which would be fuel injected. Carburetor was L model.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Here is the info returned by the Rockauto for the 1988 (Sorry I did not know those parts were different on the 1988 Festivas)
Home FORD E7GZ-10884-BTemp Sending Unit - Ford (E7GZ-10884-B)
1988-1989 Ford - e7gz10884b
More Information for ULTRA-POWER 1T1122
Continue Shopping ULTRA-POWER 1T1122
$1.96
PriceAdd to Cart
Point to Zoom
Sender; w/Gauge Ultra-Power products come from a variety of sources including re-packaged, well-known brands and ISO/TSO/QS certified overseas factories. They share some of the same suppliers as the big brands do but keep costs low to pass the savings on to you.
WARNING: This product contains chemicals known to the State of California to cause cancer, and birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.Alternate/OEM Part Number(s): 12329704, 856918510, 856918510A, E7GZ10884B, TS74 ULTRA-POWER Warranty Information:
12 MonthsLast edited by 1990new; 09-03-2022, 06:52 PM.
Hope this helps- 1988 - https://www.rockauto.com/en/moreinfo...t=4748&jsn=920. 1991 - https://www.rockauto.com/en/moreinfo...=4748&jsn=1018. Note the bigger diameter of the '91 model. Yours is probably the '88, but it is easy to unscrew it and look to be sure. You could have a different head or something. Honestly, Rockauto has never let me down. I would order one from them. Good luck!
Correction to post #11 above where I wrote '88 was the first year for fuel injection. Of course it was '89 and I knew that but mistyped and now it's too late to edit and correct that post.
You are forgiven... I'm 77 years old and my typing fingers are getting more frequent short circuits from my brain than they used to also... but it sure is nice to still be alive and enjoying life.Originally posted by WmWatt View PostCorrection to post #11 above where I wrote '88 was the first year for fuel injection. Of course it was '89 and I knew that but mistyped and now it's too late to edit and correct that post.
