88lx 5 spd
130k
I did what Haynes said for the ignition timing, lined it up TDC. Then I reconnected the Barometric Pressure Sensor, stayed the same. Hooked hoses back up to the vacuum advance mechanism and the engine sped up. Checked the timing again and it was maybe 15 degrees advanced. Is that right? Or is there a problem.
And for clarification, when someone talks about setting the timing are they talking about the ignition timing or something else? Thanks.
130k
