Have to keep replacing front seal because of oil leak. Any idea why? Thanks.
Front seal
If you are sure the oil leak is from the front crank area and changing the front seal did not fix your leak, my next step would be to replace the oil pump (and of course you would need a new bottom pan gasket also.)
Did you change the cam shaft seal? It's much easier to do than the crank seal.Last edited by 1990new; 06-29-2023, 07:12 PM.
