I want to rejet the Weber Escort Carb. Does anyone know what the Aisan Carb jet sizes were....
88 LX Carb Swap
You can't put the jet "size" from the original Aisan carb in a Weber, jets don't work like that. Weber jets are sized based on flow, not on size, so you could have two of the same number jets that are slightly different sizes when measured.
The escort carb will run perfectly fine on a b3 with the original jets it comes with.'88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
That's not what I am trying to do. I need the sizes of the jets of the Aisan Carb, so I can solder the jets in the weber carb and drill them to the sizes of the Aisan.
Also I had to put a new gasket on the weber carb, and when I took off the carb it had fuel pooling in the bottom of the intake manifold. To much fuel....
Are you also on https://www.facebook.com/groups/fordfestiva...Is your name Alex? I am Rick.Last edited by usmcsgt1968; 11-11-2023, 04:05 PM.SEMPER FIDELIS
