key stuck in ignition
  • key stuck in ignition
    Hello, as my description states my key is stuck in the ignition. It is stuck between off and accessory and will not depress while turning. The ignition is less than a year old, so I do not think it is normal wear and tear. I cannot start the car and I can only rotate the key like 20 degrees. Anyone had a similar issue? I am about to just drill it off the steering column.
