Steering Rack or Inner Tie Rod
  • Steering Rack or Inner Tie Rod
    Hey all. I’ve been doing a lot of front end work on my ‘88 Carby and after Shocks, CV Axles, Tie Rod ends, Control arms, wheel bearings, and brakes, I still have steering issues.
    I got her up in the air and there’s horizontal play in the right wheel. The inner tie rods were replaced at one point, but I don’t think have many miles on them. I’m afraid it’s the Steering Rack, but I’m hoping not. Those seem to be non-existent now.
    I’m guess I can’t attach a video, but I put one on YouTube.
    Thanks in advance for your advice!
    1990 Festiva - Throttle Body/Manual Transmission
    Bought in 2003 with 65k, now 219k
    1988 Festiva - Carb/Manual Transmission
    Bought in 2015 with 150k
    Her is a link to a thread I posted 2 years ago about how I replace the right inner tie rod bushing in Trixie without removing the entire rack. That was two years ago and its still doing great.
    I'm starting a new thread about Festiva Steering Racks. I have posted about racks in several other thread but it really is hard to find things in this forum as a result of the way it so unorganized... and I have contribute to that disorganization a lot myself. I see great potential for AI to be used to gather information from
    After posting this I just realized that your is an 88 and it did have the steel rack housing instead of aluminum... The busing I show using may not bit that steel housing. I had a good rebuilt steel housing but I gave it away a few years ago... don't have any more racks now.
    Good luck with yours.
      That's the rack bushing,where are you located,I'll check my assortment of racks and let you know if I have a good one like yours. NM I see you are in Texas. I'll let you know if I have one and how much to get it to you.
        That would be great. Thanks!
          I do have my dearly departed 1990 that someone set on fire a few years back. The inside was completely destroyed, but it’s possible that the rack survived. Would that work to swap out?
