Clutch pedal return spring
  • Clutch pedal return spring
    Hey guys! I’ve got a 1993 ford festiva and the clutch pedal return spring has broke . I can still drive it fine but I’m wanting to fix it correctly. The spring seems to be hard to find or obsolete. If anyone has one or can find one online I’d greatly appreciate it! Thanks!
    In case you don't receive an answer, it's unlikely Maza makes it own springs, probably just buys them by the barrel full from manufacturers of springs for storm doors, etc. Here are a couple of suggestions...
    First take the spring to your local junk yard and rise hoods until you find one the same size. Other car manufacturers probably buy their springs from the same spring maker.
    Second look up spring makers on the Internet. You might want to measure your spring, also place it on a sheet of plain white paper with a ruler placed parallel and take a digital photo which you can send to a spring supplier and ask for a quote. I looked up "6" coil spring" and got quite a few hits although all priced as a luxury item. You might also want to try you local hardware store.
    Good luck.
