Oxygen Sensor Wiring Problem
  • Oxygen Sensor Wiring Problem
    My '92 has a glitch that I cannot tell by the Haynes manual wiring schematic how to fix. My oxygen sensor wire is not plugged in and the wire end is missing. What I would like to know is what color of wire the oxygen sensor plugs into? (edit: I now know the following sentences are incorrect) I think it plugs into the wire loom to the passenger side of the radiator, high under the radiator support. If it plugs into a black w/white stripe wire then I know where it goes, if not, hopefully somebody could shed some light on the subject. Then I'll need to figure out what that black/white wire goes to. Anybody have a real wiring schematic for a '92?
    Thanks
    Dan "Levitan"
    ENFORCER - Midwest Festiva Inc., Iowa
    #2 .....Cheesehead
    #3 '91 White - Donor Car
    #4 .....Montana Project
    SOLD----Levistiva for $1500
    Bought her back for $450
    yes, O2 wire should be black, connector located on the front of the engine, near thermostat housing.
    Jim DeAngelis
