Is it just me or is there no diagram for the ignition switch in any of the manuals? Ive got the haynes, 1990 factory, and EVTM. There are 5 heavy gague wires and 4 light gague wires. I need to identify them for my remote start instalation! I wanted to do this while my dash is off but that means gettin er done this weekend.
Ignition Switch Wiring
did you look in section 149 (Component Testing), cell 6 (ignition switch) of the EVTM I think?
five heavy wires;
white = battery feed
blue/red = accessory (voltage in acc & on)
black/red = on (voltage in on)
black/white = ignition feed (voltage in on & start)
black/blue = start (voltage in start)Jim DeAngelis
Thanks.
Now i need to figure out where a few of the remote start wires go
I think i got it all figured out except for purple and green. Do i cut the balck/blue start wire and put purple on the starter side and green on the key side?
Remote start harness // Ignition circuit
Purple ?
Green ?
Red -> White
Orange -> Blue/Red
Pink -> Black/White
Red -> White
Pink/White -> N/A?
Red/White -> White89SX funtop! Fully loaded!
RIP 90LX
I think i got it all figured out except for purple and green. Do i cut the balck/blue start wire and put purple on the starter side and green on the key side? correct
Purple ? see above
Green ? see above
Red -> White Correct
Orange -> Blue/Red Correct
Pink -> Black/White Correct
Pink/White -> N/A? Correct
Red/White -> WhiteI don't think this one is needed. Pretty sure it's tied to the pink/whiteJim DeAngelis
that wire will only have 12V when the key is in the ON position it will however lose power when switched to start but regain 12V once key is released and returned to run.
*** Just a disclamer adding a remote starter to a manual trans can be very dangerous if car is left in gear and then started ***
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
Originally posted by Festiva_tunnerthat wire will only have 12V when the key is in the ON position it will however lose power when switched to start but regain 12V once key is released and returned to run.
FYI, festivas have an neutral saftey switch so if you install the system properly the car wont start in gear.89SX funtop! Fully loaded!
RIP 90LX
I double checked a few things; looks like red/white should go to white, and pink/white should go to black/red.
the Blk/Wht powers the coil and main relay
the Blk/Red powers the cooling fanJim DeAngelis
