RPM rise when clutch is pushed in?
  • RPM rise when clutch is pushed in?
    I have just switched my 89 Festiva L that has a 91 engine from Automatic to a 5spd. The car runs great, but when i go to shift, the rpm's rise for several seconds and then drop as normal. This problem occurs at every shift even when the car has warmed up. Why is this?
    Note: I left the switch on the gas pedal hooked up, not sure what it does.
    THanks for the help!
    Michael
    did you switch the PCM 9engine computer)?
    the switch on the accelerator is for kickdown,
    Jim DeAngelis
    kittens give Morbo gas!!
      Pardon me for being ignorant, but what is the PCM 9. I was told that the ecu's were the same for both a manual and automatic.
      Would any computer for a manual festiva work?
        PCM= Engine Computer. I think that 9 was supposed to be a bracket
        89SX funtop! Fully loaded!
        RIP 90LX
          FB71 may be able to help you, I do know that there is a switch that is activated anytime the car is in gear. I think this sends a signal to the computer that it is in gear rather than in Neutral. I believe this allows the engine to adjust the computer to take the load?? FB71 - Can you elaborate on that switch in the gearbox that is activated when put in gear?
