Does anyone have any tips for installing control arm/ball joints with new bushings....
I attached mine to the sway bar first (never detached that side of the sway bar from the front---- don't know if that would have helped) but then I couldn't get the control arm attached to the chassis as the inner bolt hole was not lining up.... so
I attached the control arm to the chassis then put the control arm bushing on, but the new one wouldn't fit I had to use my old ones that are not in the best of shape and then put in the ball joint.... but now it seems different driving it?
Is there a certain method to do it? I would really like to install the new bushings would it be just a matter of disconnecting the sway bar from the front and pulling it though?
