festiva leaking from freeze plug
  • festiva leaking from freeze plug
    Hi all
    Are there any easy fixes for a leaking freeze plug? I have a 91 Festiva GL. Anti-freeze is puddling up on the lip of the freeze plug where it indents into the block. I don't think it is coming from higher up.
    kned33
    91 blue Festiva GL (totaled)
    88 white Festiva L (sold)
    91 blue Festiva L (sold)
    best way is to replace it.
    1960 willys pickup
    1967 jeep cj5
    1988 festiva
    1989 festiva
    1990 festiva for parts
    1991 s-10
      Loctite 680...it is green thread locker. This product is a wicking type thread locker...it weeps into the small gaps only...like that between a nut and bolt thread...takes 24hrs to dry.
      Will be available at Car Quest, NAPA, Grainger or online...they sell really small bottles.
      It will work best if you drain the cooling system from the and spray it clean with air or brake kleen or alcohol.
      The components need to be really clean for any product to work.
      They are not that hard to change out if you rather
      Joe Lutz
      The SKATE ..... 1992L 5spd
        Frost plugs can be difficult to replace. They always rotate on you, and you often times end up knocking them in too far.
        The easiest fix is to pull the frost plug out and replace it with a block heater. Those may be hard to come by in California however.
