More Help!
  • More Help!
    i know i sound like a complete retard because im having such a hard time with my door panel but i cant figure out how to take off the window regulator without breaking it. i know theres a retainer clip. i've tried yanking on it, prying at it, and shoe strings and belts. im so used to working on older trucks. all you gotta do with them is un screw it.
    it'll do the 1/8 in 13.7, spin tires, and make all my drunk buddies giggle.
    "I like a Festiva because there's less car to get in the way of the driving experience"
    On the back side of the handle is a 'hairpin' type clip that holds it to the shaft. Look between the door panel and the back of the handle...you'll see it...spin the handle if necessary.
    Joe Lutz
    The SKATE ..... 1992L 5spd
      Does this help?
      1) Insert a rag like this, and work it back and forth. You may have to come in from the opposite direction with the rag if someone put the clip in backwards.
      2) Once the clip is exposed, grab it with a needlenose and pull it out. Once the clip is removed, the handle will pull right off the shaft.
      3) To reinstall, place the clip back in the handle like this, then press it onto the splined shaft.
        These are window regulators.
          Maybe I'm misreading the original post. I know what the regulator is, but from what he's describing it sounds like he's just trying to get the crank off. Am I wrong? If so, I can remove my rather large pictures.
            ^^ I think your pics is what he was looking for.
            93 GL modyfied!!!
            :fish:
              yes, the crank was what i was talking about. i've heard them called window regulators before. but thank you very much for the pictures.
              i swear to god my car would just explode if it wasnt for this website.
                That is an awesome way to remove those clips ! ! ! I have to give you props on an awesome idea.
                96 Ford F-150 XLT
                93 Festiva L (Modified)
                92 Festiva L
                68 Mustang GT 428cj
                  I can't really take credit for it. It's in the Haynes manual. But it's a bit hard to explain in words. You know what they say about pictures.
                    all went great. i got the door panel off, the hardest part was getting the rod off the handle
                    thanks for the help
