what kinda of paint do they put in those kits? because i need a whole lot of it. i got like 3 lines still working. and should i use masking tape to tape it off?
rear defrost repair
Packrat427, you have more experience with this stuff than most please advise!'93 Blue 5spd 230K(down for clutch and overall maintanence)
This one has more info ..
My actual fix ..
As you read , you will see that I tried using masking tape , the little piece that they give you is too wide in the kit .
I tried everything that people said would work , copper paint from a hobby store , silver model paint .
The one that actually did work was the Permatex brand , I know there are others , but none in my town , the Permatex was not cheap ,for such a small bottle , $10.00 a bottle and is barely enough for 3 lines .
The bad thing about mine was every line was bad .
If you do not have any luck , the next answer in in my last link
Hope that helps.------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
