i have a 90 festiva with 1.3 fi. the car idles great and so far had no trouble until recently. it has 251000 miles tho. the car spits and almost dies goin down the road...accelerating and cruising... as if the thing aint getting any gas. i replaced the fuel filter and air filter, it is getting fire but still does this. the check engine light comes on only when its messin up. auto parts store cant check the check engine light bc it only comes on when it does this...any suggestions?
need help
im not sure what the sto connecter is. i have a haynes manual tho...il look it up. i know its getting proper fuel pressure and the injectors are good...i have ran fuel injector cleaner in my tank for the last 5000 miles. its a sensor for sure. just cant find out what one. the check engine light came on goin down the road so i did a test the maual told me to do..(makes the check engine light blink a code) and the code was the oxygen sensor. i replaced it and it didnt do a damn thing. but the check engine light has not come on yet. im lost...bout ready to take it to a ford dealership and tell em to fix it.90 L FI..second B3
90 L Parts car
Jay
clogged injectors, not enough air, ignition coil going out***, i don't think it is the tps, timming off**, fuel pump relay makes sense, fuel pump going out, clogged filter on the pump... list goes on... PM FB71 about this he is a ford tech and if he is willing to help then he could prolly help alot!
burnt red?? thats an odd one. hmmmm might be rust did ur car sit for a while? it might be rust from the cyclender walls on ur plugs from running it and the rings on the pistons scraping rust off... better do a compression test. hmmmm well I am gonna go search for some food for thought...
