How to avoid noises in the dashboard?
  • How to avoid noises in the dashboard?
    Hello: I am writing from Colombia. I have been trying to solve a lot of noises my car has, but I have not been able to remove the "clocks" (speedometer, temperature and fuel gauges, etc). Does anybody know how to do it? That is the only problem my car has. Actually, in Colombia my car is a Kia Pride.
    Welcome to the forum !!
    1. disconnect neg battery cable
    2. remove four/five screw holding the cluster bezel( a short Phillips comes in handy )
    3. unplug rear wiper switch and rear defrost switch if equipped
    4. Remove four screw holding the cluster
    5. Remove speedo cable from transmission
    6. Pull cluster out away from dash and reach behind the cluster and release the locking tab holding the speed cable to the cluster
    7. Lift the locking tabs on the two electrical connectors behind the cluster and remove the connectors.
    8. remove cluster
