i recently purchased a 92 festiva gl with around 71000 miles on it. while driving i noticed that the transmission slipped a little when shifting. not all the time, just sometimes. so today after i get off of work, after driving 40 miles or so, i get home and decide to check the fluid. i let it idle for a few minutes and when i pulled the dipstick, fluid went everywhere. all over me, the engine, everywhere. so i'm guessing that there is pressure building up somewhere. any ideas? maybe it had too much fluid to begin with?
auto tranny problem
It is suppose to be running when you check, and theres a vent tube right on the top, its a rubber tube with a metal plug in the end, this plug actually has holes along the side, and it sounds like yours is plugged up, this will cause the case to pressurize, mine did this once, I had to take the metal thing out of the end of the tube and clean the passages, that should fix it right up! :wink:
