head bolts finding problems
  • head bolts finding problems
    can anyone tell me where i can get head bolts for the 1.3 l engine i bought the gaskets but cant get the bolts where can i get them
    jisengine.com should have them in stock, But you won't find them in their online catalog
      dude, stock bolts are reuseable
        ^^^^^^ayep^^^^^^
          how do i get them then i wana finish it before winter is done my 74 bettle cant handle summer
            yep! reuse your old ones and it's working just fine. Dont forget to re-torque it after the 100 and 500 miles of driving.
              uh, reuse the ones you had already
                head bolts are torque to yeild....the thread stretch. If i was rebuilding a engine or installing a new head, i woudn't be using old rusty crusty head bolts.
                  so who sells the head bolts jesus i wana get it done i need my car asap and i need a simple piece under the throttle body that is broken
                    Just a clarification...torque to yield does not mean they strech...it means that if the are loaded any more...beyond yield...they will not recover. Also, if the threads are properly made and engagement is suffice...they will be stronger than the body diameter of the bolt.....just a clarification.
                    Joe Lutz
                    The SKATE ..... 1992L 5spd
                      This was discussed a few weeks ago, Festy bolts were not TTY, I have reused the same ones on 3 diff heads, no probs that not overheating wouldn't solve
                      That said, I inspect em rto be sure they are all the same length, then soak the bolts in PB blaster, and let em sit overnight. I THEN chase them up with a die to be sure they have no rust or dirt in the threads.
                        Oh yeah, a link to the previous discusion
                          not all head bolts or studs are torque to yield, that depends on the engineers who design the block/head combo. in our case, festy bolts may be reused as many times as needed if torqued properly.
                            well i lost naby 2 or 3 bolts so yeah i need them lol
                              yer old friend the bone yard!!!!
