Hi all,
I getting a lot of hesitation, backfiring, and stalling on my 88 Festiva. The exhaust smells "rich". I have to pump the pedal quickly to keep it alive while driving. There is also a lag in response - when I press the pedal, the engine revs after a half-second or so. Also, when press my clutch pedal, the engine will momentarily rev, even though I took my foot off the gas as I pressed the clutch... part of that "lag".
Before I purchased it, it sat for a couple years.
I replaced the air filter, and ran it without one, neither helped.
I have replaced the plugs, wires, dist. cap recently, but that did not effect the symptoms.
I don't know much about carburetors, but it seems like it's not getting enough air in the mix? I've poured and sprayed various carb cleaners into it, to no avail. Are there some air passages inside the carb that could be plugged?
Any suggestions?
Thanks so much,
Erik
Any suggestions?
Thanks so much,
Erik
