My shift rod( the one that has a rubber boot)that connects to the tranny has a leaking oil seal but I cant replace and pull it out because of a letter T like rod at the end of the rod and what I dont know is if this rod can be pulled out from the tranny or not... My mechanic and I are so puzzled so pls help.. Il try to POST some pic tom.. The oil seal has lid that holds the rubber boot. I hope you can picture it out with my explanation
