Ok so i brought the festy for the etest before i go and rip the engine out... and it failed... NOx emission... not by much though.. limit is 1021 ppm and the car hit 1300 ppm.... i know that its caused from high temperatures in the cumbustion chamber... i did the usual tne up before i took it and everything..
I'm thinkin maybe dirty inectors causeing a lean mixture thus causeing high temps.. everything else went amazing..
I think i will just run some cleaner through it.... this whole emission thing through me off track for the rebuild!!! im running out of time! haha spring is comming...
I was wondering if anyone knew if instead of puting it on the rollers for an etest,,, if a 2 stage idle test would help with NOx emissions because theres no load on the engine.. possibly not working soo hard on the engine... I know they do that to some hondas when thier too low to make it on to the machine...
If that will help then i have no problem making it extremely low for now
lol
Any ideas would be great... i tried searching for info on 2 stage idle tests and whaether they help but with now luck....
Thanks,
Rob
P.S. if i knew how to up load pics id show the progress thats being made...
in the middle of sandblasting any rust on the floor right now.. its gonna be sick!!
lolAny ideas would be great... i tried searching for info on 2 stage idle tests and whaether they help but with now luck....
Thanks,
Rob
