Wow, first time I've used it in a transmission. I'm shocked!
Anyways, bought a 4Runner with almost 198k miles on it.
Drained out 4 quarts (of 4.8 quarts) from the transmission and filled it with fresh fluid. I then added 4 oz of www.auto-rx.com which I have used successfully on many engines.
Drove it 1100 miles give or take a bit and decided to check the fluid level to make sure it's not leaking. OMG! The stuff was almost black.
So here's a picture of what I drained out. I replaced another gallon of fluid today and added another 4 oz of auto-rx. I guess I'll check it again in another 1000 miles or so.
On the paper towel are a few drops of the fluid I drained out of there and to the far right a drop of brand new ATF. What a difference!
I've been encouraging everyone to use it on their motors for years, but if you have any significant amount of miles on your vehicle you might want to do the automatic transmission also.
I haven't noticed a difference in shifting or anything, but comparing immediately before and immediately after the fluid change I notice it goes into reverse a lot quicker when I shift. Less of a "pause".
